my alignment lable styles lable the beginning and end of the alignment in two different ways. I would like to get rid of the even foot station lable at the beginning and end and also possibly use some abbreviation other than "bp sta" and "ep sta". I am not able to figure out where i can change those or if it is even possible.
Solved by ToddRogers-WPM. Go to Solution.
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
Mark Green
If you want to delete them, hold the CTRL key down and select them. That way you can delete them independently from the other labels.
