Solved by Jay_B. Go to Solution.
When entering Quickproperties @ command line and selecting a Civil 3d Alignment Label a dialog appears stating:
"Alignment Station Label Group
This object type is not supported by quick properties panel"
If you wish to hide the end Station label:
ctrl + lt click on end station label text>Delete
Reset restores it.
Jay,
Thanks, I learned two new things from this post. I had never typed quickproperties, this may help me get everything the way I want faster. Also I used to alway use the ctrl select method, but I thought you had to set display to no in the properties box.
Thanks!!!!
