Is there a way to set alignment labels layer automatically?
Ideally I would like to create a suffix to C-ROAD-TEXT same as to alignment
example:
C-ROAD-Penstock_Option#1
C-ROAD-TEXT-Penstock_Option#1
Because I don't like to have labels of alignment when the alignment is turn off.
Solved by troma. Go to Solution.
Sure, Settings tab of toolspace>rt click on dwg name>edit drawing settings>Object layers tab>
modifier column>alignment labeling>suffix.
Mark Green
Working on Civil 3D in Canada
