I would also like to do this to add to my delta. I have Civil 3D 2009.
I thought of going into expressions, but it won't let me put in text with an IF function.
I am trying to create a curve data table.
If you return a value for the text height using an if expression, you can send 2.5 say for text 2.5 high if you want a text component to show and 0.0001 if you don't want to show the text.
I have used this for various expressions in labels, you just have to have a component and matching expression for each possible variation.
Here's an example for C3D 2009. I think the option to have lt or rt is available in later versions of C3D.
Whoops, looks like I forgot to paste the link: http://style.civil3dreminders.com/checkrightorleft
Great, thank you!
Is there an easy way to copy expressions from one file to another? I tried drag and drop and it doesn't work. I also just copied the style of RightLeft, but only CheckRight and CheckLeft expressions went over.
I haven't been in the file in a long time, but if an expression didn't come over it's likely I used it temporarily and wasn't used in the style.
Your CheckRight expression, for example, uses the CheckValue expression and the EndDirDouble expressions. But my CheckRight expression adds a bunch of stuff:
2f59b6c1221548557fc13894ed7253e0CheckValue
I think since it can't find it. I can just create new expressions and copy it over then!
Thanks again!
I set all my expressions up, then realized that I was using Alignment Curve Table Styles, and there are not components in it that I could create for RT and LT. The only thing I could think of is to use an alignment label with appropriate spacing between the STA, DELTA, RADIUS, etc. and create my own table (box around the labels)...
