Hi friends,
I'm having problems with the alignment label. I'd like label the stations in intervals of 5 stations. For example, [0 + 0,00], [5 + 0,00], [10 + 0,00], etc. And the staions between each main station must be without label. How can I solve this question?
Thanks!
Solved by Jay_B. Go to Solution.
Also If you always label the alignment stationing at intervals of 5 you can set this up in your template by creating an alignment "Label Set" which has the desired interval specified for the "Major Station" type.
Then use this label set to add the alignment labels..
