Is there anyway to get the expression format in Degrees, Minutes, Seconds?
wrote in message news:5327808@discussion.autodesk.com...
Expressions to the rescue! (provided you're using 2007)
Create two new Expressions, Latitude and Longitude, insert the northing or
easting property into the expression. At the bottom of the expression editor
choose to format the result as Latitude or Longitude, as needed.
The characters in the code refer to the formatting of the component and
usually follow the same order they are listed on the right.
Uft - Units Feet
P# - precision
RN - round normal
OF - output full
... and so on.
