Show only
Search instead for
Sure it does. In the following image the label style for the top alignment has the Plan Readability set to True. The bottom one uses a style which has this set to false.
Yes ,It's correct ,but regarding to my question,I have only one alignment! I think thin is because of direction of priliminary polyline that ,some poly lines drew right to left and other drew left to right. by the way, this method didn't work for me. I appreciate you for your consideration. Thanks Hamid
