Civil 3D Forum
Alignment label direction
8 REPLIES 8
Message 1 of 9
509 Views, 8 Replies
Hi
after creating an alignment I don't know why the station labels directions are different?
Thanks for your help in advamce.
8 REPLIES 8
Message 2 of 9
Jeff_M
This is controlled by the Plan Readability properties in the Label Style
Message 3 of 9
in reply to: Jeff_M
Thanks for your respond,
But it dosen't wrok.
Message 4 of 9
Jeff_M
Sure it does. In the following image the label style for the top alignment has the Plan Readability set to True. The bottom one uses a style which has this set to false.
Message 5 of 9
in reply to: Jeff_M
Yes ,It's correct ,but regarding to my question,I have only one alignment!
I think thin is because of direction of priliminary polyline that ,some poly lines drew right to left and other drew left to right.
by the way, this method didn't work for me.
I appreciate you for your consideration.
Hamid
Message 6 of 9
Jeff_M
Can you post your drawing and let us know which version of C3D you are using?
Message 7 of 9
I work with Civil3D-2013.
Message 8 of 9
Jeff_M
OK, as I said, this is controlled by the LabelStyle's Plan Readability setting.
Message 9 of 9
in reply to: Jeff_M
I appreciate you for your help.
Rail Community
