use either Pipes>Add Pipes to Profile view
or
pick the profile view, right click, go to the pipes tab and choose the pipe
numbers you want.
Dana Breig Probert, E.I.T.
http://www.civil3d.com
Register for the AUGI CAD Matinee in Philadelphia on May 17.
I'll be teaching: Using Civil 3D 2008 for Stormwater Management Tasks and A
Subdivision from Boundary to Plat with Civil 3D 2008
Visit http://www.cadmatinee.com/philadelphia/default.asp for more complete
agenda and registration.
wrote in message news:5549129@discussion.autodesk.com...
I have a small sanitary network with 4 new manholes attaching to an existing
manhole. I am unable to use a reference alignment or surface. After I have
the network designed, I make an alignment from the network and let it make a
profile view. When I select the first and last manholes to define the
alignment, the entire network highlights as if selected. However, the
actual alignment begins at the second manhole omitting the first manhole and
pipe. These do not show in the profile either even though when you look at
the profile view properties, both the first manhole and first pipe are
checked that they are drawn in the profile. How do I get them included in
the alignment and subsequently the profile?
