Is there a way to connect two sperate lines with a tangent curve wihout moving the two ends of the lines where the curve is connecting ?
I cant find a way to do it.
Thanks in advance.
Tony,
Solved by odoshi. Go to Solution.
Hi Tony,
There isn't because there is no guarantee that the 2 lines are oriented in such a way that there is a curve solution that is tangent at both ends.
You could float a curve off the first line and specify a pass-through point at the start of the second, but the second point may not be tangent.
Better to use a Free curve that is "free" to slide at either end to ensure tangency.
Mike
