Civil 3D Forum
Alignment entity contraints
3 REPLIES 3
dnl999
164 Views, 3 Replies
Why are some of the alignment entities constraints changing in Civil 3D ?
For example, I have a number of Spiral-Curve-Spiral groups but for some reason (maybe after editing ?) these groups somehow have changed to individual free spirals and curves.
Is there a way to prevent this from happening ?   Or is there a quick way to convert these independent entities back into the Spiral-Curve-Sprial groups without having to export and then import back ?  Thanks for any reply in adavace.
3 REPLIES 3
dnl999
in reply to: dnl999
The alignment has not been edited.
Just close and open again the alignment entity constraints changed.
Do not know why this is happening.
tcorey
in reply to: dnl999
If you put the alignment on a locked layer does this still happen?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
sboon
in reply to: tcorey
Check the Constraint Editing tab in the Alignment Properties dialog.  Also check the help files.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Rail Community
