Civil 3D Forum
Alignment curve labels
7 REPLIES 7
Message 1 of 8
2236 Views, 7 Replies
Hi there
I have made a Curve label style as shown in the attachment. I have to add this as a multiple segment label, which does not update when I extend or shorten my alignment. I want to use the label style in a label style set for an alignment. So how do I do that?
Kind regards.
7 REPLIES 7
Message 2 of 8
Nobody wants to give this a try?
Message 3 of 8
Reply from Autodesk rep:
It is not possible to add detailed geometry information in the label sets in they what you show in the image.
So that kind of sums it up. Smiley Sad
Message 4 of 8
johngordon6189
I am a bit confused, I can label my alignment and have those labels update if I happen to alter the alignment.  How are you labeling the alignment?
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Message 5 of 8
andrewpuller3811
Not sure what this is about. You can add the curve rad as shown quite easily in civil 3d.
To add a label style to an Alignment Label Set you need to create the label style in the Alignment - Label Styles area.
You can make the curve radius label style under Alignments -> Label Styles -> Curve
To get the label to work on lines, you will need to make a false radius label style under Alignments -> Label Styles -> Lines
Just set the display component to R = (infinity symbol)
Then just add your alignment curve label style and alignment line label style to a new alignment label style set.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 6 of 8
Jeff_M
in reply to: andrewpuller3811
Andrew, I don't see the option to add line/curve labels to a label set. Is there a trick I'm unaware of?
Jeff_M, also a frequent Swamper
Message 7 of 8
andrewpuller3811
in reply to: Jeff_M
No, you are absolutely correct.
Big egg on face moment there. :l
Sorry about that.
Andrew Puller
Civil 3d 2021
Message 8 of 8
in reply to: johngordon6189
Hi John
I'm labeling my alignment using the "add labels" -> "Multiple segment" from the contextual ribbon of the alignment. Yes they update via the alignment at minor changes, but have you tried adding geometry or deleting a curve and adding one again?
If you have a workaround that is easier than; "delete labels" and add multiple segments again I would like to know about it.
Rail Community
