Hi there
I have made a Curve label style as shown in the attachment. I have to add this as a multiple segment label, which does not update when I extend or shorten my alignment. I want to use the label style in a label style set for an alignment. So how do I do that?
Kind regards.
Reply from Autodesk rep:
It is not possible to add detailed geometry information in the label sets in they what you show in the image.
So that kind of sums it up.
I am a bit confused, I can label my alignment and have those labels update if I happen to alter the alignment. How are you labeling the alignment?
@Anonymous wrote:Reply from Autodesk rep:
Not sure what this is about. You can add the curve rad as shown quite easily in civil 3d.
To add a label style to an Alignment Label Set you need to create the label style in the Alignment - Label Styles area.
You can make the curve radius label style under Alignments -> Label Styles -> Curve
To get the label to work on lines, you will need to make a false radius label style under Alignments -> Label Styles -> Lines
Just set the display component to R = (infinity symbol)
Then just add your alignment curve label style and alignment line label style to a new alignment label style set.
No, you are absolutely correct.
Big egg on face moment there. :l
Sorry about that.
Hi John
I'm labeling my alignment using the "add labels" -> "Multiple segment" from the contextual ribbon of the alignment. Yes they update via the alignment at minor changes, but have you tried adding geometry or deleting a curve and adding one again?
If you have a workaround that is easier than; "delete labels" and add multiple segments again I would like to know about it.
