I am creating alignments and profiles of the edge of pavement, along curb returns, based on a corridor feature line created from an alignment and profile of the curb return top of curb.
I have done about 12 returns with no problem, but I have one return that when I use the Alignment from Corridor command it creates an alignment that does not follow the feature line. instead of the 36.5' radius it is suppose to have, it has a 172.71' radius.
I have attached a pic of a good return which has the same delta as the bad return. The blue line in the bad pic is the alignment it created.
I was wondering if anyone else has run acrossed this and if there is a fix.
Dave
Shot in the dark:Mid ordinate setting?
Joe Bouza
Joe,
I'm not sure what setting I would need to change, but the corridor feature lines created before and after this one have all worked fine. I have deleted this corridor and recreated it with the same results.
I have compared the top of curb alignment and profile settings for this return with the others and I cannot find any settings that are different.
I tried creating the alignment and unchecked the profile option and it still created the wrong alignment.
So the work around was to manually move the bad alignment to the correct location and use that alignment to create a profile from the corridor surface. Good enough.
I think this curb return is just unhappy with being on the wrong side of the street.
Dave Locke
C3D 2011
I missed this back in 2012. When generating the corridor FL clear the check box for smoothing. Odd but I have found not using "Smoothing" the FL is true to the corridor
Joe Bouza
Found the alternative solution. Create a 3d pline from corridor, then quick profile from the 3d pline. Export this quick profile to XML and then import the XML. It works perfect.
