Civil 3D Forum
Aliases acting strange.
2 REPLIES 2
230 Views, 2 Replies
Basically my default aliases are not working. I hit C and I get copy not Circle. I hit EX and I get explode.
Most of the commands are like this. So most of the lisps I have that use the alias short cuts are not working now.
The strange thing is that I have re-installed autocad. The really strange this is that some of the alias`s I have made still exist after the re-instal. I have also took the .pgp file from another user and replaced my own. I checked the file and all the default aliases are there and look correct. I can't override them either.
Does autocad pull aliases from another location? Is this a error with the autocomplete when you type in commands?
Any help would be very welcomed.
Cheers
Autocad 2014.
Tags (2)
2 REPLIES 2
Jay_B
To find out where your acad.pgp is being loaded from enter (findfile "acad.pgp") at the command line > Enter.
Pretty sure the first pgp found in directory listing under Options > Files Tab " Support File Search Path" is the one that is loaded.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
in reply to: Jay_B
Oh man thanks. It was linked to a .pgp file in my documents. I must have put in there some time ago. Arg I just kept going back to the default location.
Cheers!
Rail Community
