Civil 3D Forum
(Again): Plotting points at stations of horizontal alignment,
15 REPLIES 15
Message 1 of 16
JamaL9722060
955 Views, 15 Replies
I wanted to plot points at the stations of horizontal alignment to be then able to capture their XYZ and thus can be stored on the GPS devise for setting out on the field.
The points are not plotted (please, see the attached screenshots
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
15 REPLIES 15
Message 2 of 16
DaveDrahn
in reply to: JamaL9722060
What happened after hitting enter <ending station....> on the last screenshot?
Message 3 of 16
JamaL9722060
in reply to: DaveDrahn
Many thanks DaveDrahn,
The points are not plotted! Not added to the drawing.
What might be wrong with it then?
Jamal Numan
Message 4 of 16
DaveDrahn
Can you post the dwg here (or on dropbox, google drive, sky drive, etc)? I'd look at the profile values first, do they make sense with the stationing requested. Also look at the points list in prospector to make sure they are not being added under a non visible style, etc. The basics but it's always good to make sure you're checking there first.
Message 5 of 16
JamaL9722060
Many thanks Dav for the help,
The dwg is attached. All what I wanted to do is to capture the xyz values of the horizontal alignment of the cureve as shown in the attached screenshot
Best
Jamal
Jamal Numan
Message 6 of 16
Jay_B
Jamal,
On clip_395.jpg, try setting prompt for elevations to Automatic.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 7 of 16
DaveDrahn
It worked fine using the method you were trying. Except your V-NODE layer is frozen....
Good reason to check all the obvious first. And you won't get Z values without a defined profile, but this brought them into the alignment just fine.
Message 8 of 16
JamaL9722060
Thank you very much Jay_B and Dave for the help,
The elevation is set to be Automatic + the layer “V-NODE” layer is unfrozen (attached), nevertheless, it doesn’t work. The points are not added to the drawing.
The software sticks at the “Ending Station” step (attached) and doesn’t want to leave it
Appreciated Dave for the screenshot. You got it. For me I’m still struggling
Jamal Numan
Message 9 of 16
DaveDrahn
Try it again, not going to the end station. Instead, type in 160 (0+160) as the final station.
Sent...
Message 10 of 16
Jay_B
I added a short profile Elevations 300-303 and it works here with 2014 Civil 3d.
Points>Alignment>Measure used as in your captions.
(ALL point creation Command Settings were set to Automatic)and did a range from 0+000 to 0+060 where my profile ended.
Also had to thaw V-node layer as previously mentioned.
C3D 2018.1
C3D 2016 SP4
Message 11 of 16
JamaL9722060
in reply to: Jay_B
Many thanks Dave and Jay_B for the prompt help,
Sorry but still it is not working for me.
I tried it again from scratch (the dwg is attached) but sounds not to work at all. The software sticks at “Ending station” and doesn’t want to leave it.
I tried to type the “ending station” in all possible formats but did not work. Almost desperate!
What might be the issue then? Why should it be very challenging like this?
Jamal Numan
Message 12 of 16
Jay_B
Did you try for example 164.00 (leaving out the +) ?
And does your profile end before the end of your alignment Station of 0+164.20?
C3D 2018.1
C3D 2016 SP4
Message 13 of 16
DaveDrahn
I thought the same thing Jay mentions. Try it again and instead of accepting the default ending station type in 164.
Message 14 of 16
JamaL9722060
Many thanks Jay_B and Dave,
I tried typing 164 but not 164.20 and it did work! Is this a bug?
Jamal Numan
Message 15 of 16
DaveDrahn
Possibly. It's possible that the end station is really 164.19965, so 164.2 is beyond the end. But Autodesk should know better, so I'd say yes.
Message 16 of 16
JamaL9722060
Many thanks Dave. Sounds that the method you have recommended works fine
Best
Jamal
Jamal Numan
Rail Community
