Civil 3D Forum
After Lofting, Autocad/Civil 3D closes when saving the file.
5 REPLIES 5
SantiagoSoto1974
395 Views, 5 Replies
Hello Gents
The issue here is that I can not save the CAD file with the shapes I need to provide to the client.
I use the Civil Infrastructure Suite 2013.
The program makes it possiible to create the Lofting Surface between sections/profiles (from two to eight), but when saving the file, after creating the surfaces, Autocad is forced to close the program suddenly, therefore, no joy on saving the shape  acheived by the program, again and again.
I hope you can help, it used to work in 2012R.
Thanks and Kind Regards.
Santi.
SYSTEM GENERAL DESCRIPTION
OS Name    Microsoft Windows 7 Professional
Version    6.1.7601 Service Pack 1 Build 7601
Other OS Description     Not Available
OS Manufacturer    Microsoft CorporatioN
System Manufacturer    Intel Corporation
System Model    W2600CR
System Type    x64-based PC
Processor    Intel(R) Xeon(R) CPU E5-2687W 0 @ 3.10GHz, 3101 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date    Intel Corp. SE5C600.86B.01.02.0009.042520121156, 25/04/2012
SMBIOS Version    2.6
Windows Directory    C:\Windows
System Directory    C:\Windows\system32
Boot Device    \Device\HarddiskVolume1
Locale    United Kingdom
Hardware Abstraction Layer    Version = "6.1.7601.17514"
Time Zone    GMT Daylight Time
Installed Physical Memory (RAM)    128 GB
Total Physical Memory    128 GB
Available Physical Memory    119 GB
Total Virtual Memory    256 GB
Available Virtual Memory    246 GB
Page File Space    128 GB
Page File    D:\pagefile.sys
DISPLAY INFORMATION
Name    NVIDIA Tesla C2075
PNP Device ID    PCI\VEN_10DE&DEV_1096&SUBSYS_091010DE&REV_A1\4&2823764D&0&0018
Adapter Type    Not Available, NVIDIA compatible
Adapter Description    NVIDIA Tesla C2075
Adapter RAM    Not Available
Installed Drivers    nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver Version    8.17.12.9703
INF File    oem37.inf (Section017 section)
Color Planes    Not Available
Color Table Entries    4294967296
Resolution    2560 x 1600 x 59 hertz
Bits/Pixel    32
Memory Address    0xEC000000-0xECFFFFFF
Memory Address    0xF0000000-0xF7FFFFFF
Memory Address    0xF8000000-0xF9FFFFFF
I/O Port    0x0000CF80-0x0000CFFF
IRQ Channel    IRQ 4294967241
Driver    c:\windows\system32\drivers\nvlddmkm.sys (9.18.13.697, 12.82 MB (13,443,944 bytes), 10/10/2012 21:22)
Name    NVIDIA Quadro 6000
PNP Device ID    PCI\VEN_10DE&DEV_06D8&SUBSYS_076F10DE&REV_A3\4&23A08B03&0&0010
Adapter Type    Quadro 6000, NVIDIA compatible
Adapter Description    NVIDIA Quadro 6000
Adapter RAM    (1,048,576) bytes
Driver Version    9.18.13.697
INF File    oem125.inf (Section030 section)
Color Table Entries    Not Available
Resolution    Not Available
Bits/Pixel    Not Available
Memory Address    0xD0000000-0xD20FFFFF
Memory Address    0xD8000000-0xE3FFFFFF
Memory Address    0xE0000000-0xE3FFFFFF
I/O Port    0x00003000-0x00003FFF
IRQ Channel    IRQ 4294967278
I/O Port    0x000003B0-0x000003BB
I/O Port    0x000003C0-0x000003DF
Memory Address    0xA0000-0xBFFFF
5 REPLIES 5
I'm not on 2013 so don't know anything about this problem. But, as a workaround, could you wblock the lofted surface to preserve it. It's possible that it could then be inserted after the drawing is closed and reopened.
As I said. I'm not familiar with the problem and have never tried this. I'm just extrapolating from what I know of the program.
Allen
Allen Jessup
CAD Manager - Designer
BTW. That sound serious enough to open a Service Request with Autodesk, if your on Subscription.
Allen
Allen Jessup
Hello Allen
Thanks for the comment, but the last thing I would like, is a "workaround".
I am afraid I can not admit this kind of behaviour by the software, that we all like, and keep in our businnes, in order to produce the best for our clients.
We need to keep improving this... "thing".
Thanks again, let me try other routes and I will keep you informed.
Santi
Hi Santi,
I certainly wasn't suggesting it as a final solution. But sometimes you have to take the quick choice when a deadline looms. Let us know what Autodesk says.
Allen
Allen Jessup
I know, I know
Please do not get me wrong.
Autodesk is in the know right know, therefore, as soon as I am in the know of the "Doctors Recipe", I will let you know, and may be... they will let you know.
Again... we need to keep improving, and very fast.
Thanks a lot for the reply.
Santi
Rail Community
