Civil 3D Forum
After C3d 2012 patch install
5 REPLIES 5
JOHNHAAG6922
360 Views, 5 Replies
FYI...After install of patch could not load database raster images in Map toolspace without starting C3d as administrator.  Modified shortcut to always load as administrator then would get errors trying to insert Google data.  Opened C3d as non adminstrator then was able to insert Google data.  Has anyone else experienced these issues after installing patch?
John J. Haag, P.E.
Haag Engineering Consultants, Inc.
5 REPLIES 5
I have not seen that behavior. Can you post the error message you are getting?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
JOHNHAAG6922
in reply to: JOHNHAAG6922
Attached are two screenshots with errors for both cases.  I can load rasters in Map when run as administrator and can load Google data when not as administrator.
Haag
John J. Haag, P.E.
This looks like permission issue. Could you either login as administrator and try to import  Google Earth image or right click the Google Earth Icon and change the Google Earth Properties to run as administrator.
Almas Suljevic
Autodesk, Inc.
Yes!  That worked running C3d and Google Earth as admin.
John J. Haag, P.E.
BTW...I always log on as admin.
Haag
John J. Haag, P.E.
Rail Community
