FYI...After install of patch could not load database raster images in Map toolspace without starting C3d as administrator. Modified shortcut to always load as administrator then would get errors trying to insert Google data. Opened C3d as non adminstrator then was able to insert Google data. Has anyone else experienced these issues after installing patch?
Solved by AlmasSuljevic. Go to Solution.
I have not seen that behavior. Can you post the error message you are getting?
Attached are two screenshots with errors for both cases. I can load rasters in Map when run as administrator and can load Google data when not as administrator.
Haag
This looks like permission issue. Could you either login as administrator and try to import Google Earth image or right click the Google Earth Icon and change the Google Earth Properties to run as administrator.
Yes! That worked running C3d and Google Earth as admin.
BTW...I always log on as admin.
Haag
