I'm research this topic.
From my aerial mapping company I get an a Aerial Topo and Coutour/spot elev in Autocad.
I then takle the controur/spot elev to create a Surface (TIN). I then edit the surface until I my contours matches the countours on aerial topo. The problem is at sharp turn in the contour, the sufure want to cut accross, so I have to add points. Also I think I'm dupication the work.
I think my Aerial mapping company is using a software call Datum.
My questions, is anyone getting an Autocad Civil 3d surface from their Aerial Mapping Company, if so what is the format?
In general Aerial Mapping companies dont us C3D.
You should request the following. Unless its been provided.
Generally they have a drawing that is strictly breaklines and points, you need that so that you can covert there breaklies to C3D Breaklines. Also you might request an ascii file of the points (spot grades) so that you dont have to convert them and you can just reference the file in your surface without actually having any of the points in the drawing, then just use the planmetrics as a xref.
Rick Jackson
Survey CAD Technician VI
