when I launch C3D 2008 i get the error message unable to load C:\Program Files\Civil 3D 2008\Civil\AeccUiModel.arx file & when I have a look in the autocad text window it says
Customization file loaded successfully. Customization Group: CIVIL
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: MAPCLASSIC
Customization file loaded successfully. Customization Group: EXPRESS
Loading AEC Base...
Loading AEC Base Extended...
Loading AEC Base UI...
Loading AEC Project Base...
Loading AEC Base GUI...
Loading AEC Schedule Data...
Loading AEC Schedule...
Loading AEC Object Explode...
Loading AEC Utilities...
Loading AecCivilBase...
Initializing.........Done.
Loading AECC Base...
Loading AECC Land...
Loading AECC Subentity Selection...
Loading Modeler DLLs.
Loading AECC Survey...Regenerating layout.
Regenerating model.
*Cancel*
C:\Program Files\Civil 3D 2008\Civil\AeccUiModel.arx cannot find a dll or other
file that it needs.
AcRxDynamicLinker failed to load 'C:\Program Files\Civil 3D
2008\Civil\AeccUiModel.arx'
C:\Program Files\Civil 3D 2008\acad.exe
C:\program files\Civil 3D 2008\Civil\AeccUiModel.arx cannot find a dll or other
file that it needs.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
AutoCAD menu utilities loaded.
Command: COMMANDLINE
Command: ShowTS
There are currently no palettes to show in the Toolspace window.
the survey toolspace window only shows a survey tab with the prospector & settings tab missing, also when I launch survey link it says unknown command, however if I go into APPLOAD & manually load in the AeccUiModel.arx everything works OK. Anybody any ideas?
