Member
Kayte
Message 1 of 3 (360 Views)
AECC Db Class Node 31C4 error
360 Views, 2 Replies
05-25-2012 01:54 PM
I'm in process of cleaning up an inherited drawing and I keep getting the following recurring 4 errors every time I audit or run a recovery. When I look through the recovery log I see the following note: "AECC Db Class Node 31C4 error". At the end of the recovery log it states the four errors are repaired -- but next time I audit there they are. Any ideas how to fid the drawing of this problem?
TRogers
Message 2 of 3 (358 Views)
Re: AECC Db Class Node 31C4 error
05-25-2012 02:13 PM in reply to: Kayte
Do a -purge, the R for RegApps.
If the issue was resolved by this method, please click on "Accept As Solution"
*Civil 3DJ*
Todd Rogers
Visit my blog here.
Member
Kayte
Message 3 of 3 (334 Views)
05-28-2012 05:43 AM in reply to: TRogers
Thank-you, I gave this a try a couple of times and couldn't get rid of the errors. I should add that even though I selected R for Regapps the routine came back with 'no unreferenced visual styles found'. I then tried again and selected ALL and the routine came back with no unreferenced for every entity the -purge looks for *except* Regapps! I do appreciate your response however and will remember the -purge routine...I had used this in the past for some recalcitrant objects and had forgotten it. So thank-you. I'm open to any further suggestions if you have them.
