Hi everybody,
I have a problem with my computer, start working with my civil program 2013 and this application called adsync.exe shortly after consumption makes most of my RAM in total is 16 gb and this application consumes 14 GB, which could be a solution other than the uninstall program?
Thnk´s in advance!!!
thats the cloud service i think
you should be able to go to the windows control panel and uninstall the autodesk sync program
DarrenP
maybe >>>this<<< is a help? At least easier to try than a reinstall 😉
- alfred -
here's an alternative to uninstalling it, don't let it start up with your computer. If you're running windows XP, then click Start, Run, type in msconfig into the white box, press OK. Next, a window pops up, click on the Startup tab, and uncheck the AdSync box, click Apply. this way it isn't always running, but you don't uninstall it.
ok
did you try any of the suggestions provided?
DarrenP
I've got the same problem. I installed Autodesk Sim 360 last week and I discovered that AdSync.exe uses 2.2 Gb of my RAM.
How can one fix this??
Hej Robin Werneskog, är du Caroline Werneskogs bror? I så fall har vi nog träffats 🙂 Jag har iallafall liknande problem med Autocad Architecture 2013 så om du hittat nån lösning på problemet så är jag idel öra.
I believe this was solved with either a hot fix of the service pack. Make sure you install all service packs.
I remember this one.
Hope that helps,
Conan Witzel
