jorge.cervantes
Message 1 of 11 (9,996 Views)
adsync.exe (Autodesk Sync) consumes all memory help!
9996 Views, 10 Replies
06-28-2012 11:00 AM
Hi everybody,
 I have a problem with my computer, start working with my civil program 2013 and this application called adsync.exe shortly after consumption makes most of my RAM in total is 16 gb and this application consumes 14 GB, which could be a solution other than the uninstall program?
Thnk´s in advance!!!
DarrenP
Message 2 of 11 (9,996 Views)
Re: adsync.exe (Autodesk Sync) consumes all memory help!
06-28-2012 11:06 AM in reply to: jorge.cervantes
thats the cloud service i think
you should be able to go to the windows control panel and uninstall the autodesk sync program
jorge.cervantes
Message 3 of 11 (9,992 Views)
06-28-2012 11:11 AM in reply to: jorge.cervantes
But any other comment other than to uninstall the application?
Alfred.NESWADBA
Message 4 of 11 (9,914 Views)
07-01-2012 12:06 PM in reply to: jorge.cervantes
maybe >>>this<<< is a help? At least easier to try than a reinstall :smileywink:
- alfred -
Alfred NESWADBA
New Member
biren
Message 5 of 11 (9,567 Views)
10-01-2012 09:24 PM in reply to: jorge.cervantes
here's an alternative to uninstalling it, don't let it start up with your computer.  If you're running windows XP, then click Start, Run, type in msconfig into the white box, press OK.  Next, a window pops up, click on the Startup tab, and uncheck the AdSync box, click Apply.  this way it isn't always running, but you don't uninstall it.
Distinguished Contributor
Vitornis
Message 6 of 11 (2,596 Views)
02-12-2014 08:20 AM in reply to: jorge.cervantes
I am also having the same problem.
DarrenP
Message 7 of 11 (2,592 Views)
02-12-2014 08:22 AM in reply to: Vitornis
ok
did you try any of the suggestions provided?
robin.werneskog
Message 8 of 11 (1,813 Views)
04-08-2014 03:52 AM in reply to: jorge.cervantes
I've got the same problem. I installed Autodesk Sim 360 last week and I discovered that AdSync.exe uses 2.2 Gb of my RAM.
How can one fix this??
robin.werneskog
Message 9 of 11 (1,772 Views)
04-09-2014 12:26 AM in reply to: robin.werneskog
I also want to add that this caused my Inventor to run slow and lagging.
New Member
Sidmayer
Message 10 of 11 (59 Views)
09-29-2014 08:09 AM in reply to: robin.werneskog
Hej Robin Werneskog, är du Caroline Werneskogs bror? I så fall har vi nog träffats :smileyhappy: Jag har iallafall liknande problem med Autocad Architecture 2013 så om du hittat nån lösning på problemet så är jag idel öra.
