Member
davidreese
Message 1 of 5 (200 Views)
Adobe Export
200 Views, 4 Replies
10-17-2012 06:35 PM
Has anyone had an issue with having Adobe x or XI installed and lost ability to export to pdf?
AllenJessup
Message 2 of 5 (186 Views)
Re: Adobe Export
10-18-2012 05:13 AM in reply to: davidreese
No. But I always use CutePDF to create the files.
Allen
LisaPohlmeyer
Message 3 of 5 (180 Views)
Re: Adobe Export
10-18-2012 05:22 AM in reply to: davidreese
No, but we use Autodesk's DWGtoPDF print driver
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
Member
davidreese
Message 4 of 5 (172 Views)
Re: Adobe Export
10-18-2012 06:01 AM in reply to: davidreese
Here is the interesting thing, I added the post after trying this at home off my work network, then on my network via VPN, and it failed both times. Tried it while hard wired to my network at work this morning and there was no problem exporting to PDF within the Autocad system as it comes without external programs. The reason I like this export method is the layering that is created within the PDF so the user of the PDF can turn off and trun on layers created in the export. So now I am a little unsure why it is having an issue one place and not the other. I suspect it is looking for a file or some driver that is referenced on our server but which is hard to access over a VPN connection. Anyway, I will leave it for the IT folks to figure out. Thanks for your responses
troma
Message 5 of 5 (121 Views)
Re: Adobe Export
12-04-2012 10:42 AM in reply to: davidreese
Autodesk's DWGtoPDF print driver includes object layers.
Credit where credit is due! Give kudos or accept as solution whenever you can.
