Civil 3D Forum
Adobe Export
4 REPLIES 4
davidreese
359 Views, 4 Replies
Adobe Export
Has anyone had an issue with having Adobe x or XI installed and lost ability to export to pdf?
4 REPLIES 4
AllenJessup
in reply to: davidreese
No. But I always use CutePDF to create the files.
Allen
Allen Jessup
CAD Manager - Designer
Lisa_Pohlmeyer
No, but we use Autodesk's DWGtoPDF print driver
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
davidreese
Here is the interesting thing, I added the post after trying this at home off my work network, then on my network via VPN, and it failed both times. Tried it while hard wired to my network at work this morning and there was no problem exporting to PDF within the Autocad system as it comes without external programs. The reason I like this export method is the layering that is created within the PDF so the user of the PDF can turn off and trun on layers created in the export. So now I am a little unsure why it is having an issue one place and not the other. I suspect it is looking for a file or some driver that is referenced on our server but which is hard to access over a VPN connection. Anyway, I will leave it for the IT folks to figure out. Thanks for your responses
troma
Autodesk's DWGtoPDF print driver includes object layers.
Mark Green
Working on Civil 3D in Canada
Rail Community
