Is there a way to create a point group of random points within a drawing and adjust the elevations for the points within that group? Some of the points in the group may have been manually created and some may have been imported by way of "Import Events"......thank you
Solved by awood. Go to Solution.
If you create the Point Group (based on whatever Include/Exclude criteria you need), then Right-click the Point Group, choose Select, then Right-click in the drawing area and choose Datum, you should be able to adjust Elevation.
HTH
Awood
