Civil 3D Forum
Additional Civil-3D installation steps?
6 REPLIES 6
Sinc
268 Views, 6 Replies
I'm getting the impression that Civil-3D installation includes some undocumented steps. The crux of the matter seems to be that C3D creates a default profile called "<<Unnamed Profile>>", which doesn't work well because of the greater-than and less-than symbols in the profile name.
So, I take it that the default profile should not be used, and the following steps should be performed immediately after installation:
1) Create a new profile, e.g. a profile named "C3D".
2) Customize this profile as desired, leaving the default Unnamed Profile untouched.
3) Open the desktop shortcut, right-click and select "Properties". In the "Target" for the shortcut, change the profile name from the default Unnamed Profile to "C3D".
4) Open the shortcuts in the Start Menu, and perform the same change as in 3).
This seems to make everything work better. It even keeps things from getting messed up when installing SP1 - well, most things, anyway. After installing the SP, the current profile is once again switched back to the Unnamed Profile, but the "C3D" profile still exists, and all the user has to do is set the "C3D" profile current to return to normal.
Sound about right?
Sinc
6 REPLIES 6
petrocat
in reply to: Sinc
That's what we do.
in reply to: Sinc
I'm using the unnamed profile and haven't experienced difficulties.
in reply to: Sinc
ditto
petrocat
in reply to: Sinc
I'm not sure he was saying that you would have problems if you used the default. The only hiccup would come when installing SP1, which apparently would change/reset settings in the Options unless you backed up your profile.
Sinc
in reply to: Sinc
Difficulties we've encountered with the Unnamed Profile:
1) We can export the Unnamed Profile, but not import it. We get an "Invalid Key" error on the import, apparently because the less-than and greater-than symbols are being parsed as some sort of tag.
2) The Unnamed Profile is clobbered when installing SP1.
There was a third issue that popped up once, also apparently because of the less-than and greater-than symbols in the profile name, but I can't recall what it was.
Sinc
Sinc
in reply to: Sinc
If this is something that is supposed to be done to every installation of C3D, then it seems to me that it should be covered in the installation instructions.
C3D is the only program I've ever seen that installs incorrect shortcuts in the Start menu and on the desktop. No other program I've ever used has required me to change the default configuration and shortcuts in order to be used "properly". And then the fact that the installation instructions ignore the issue does not help. User-unfriendly "features" like this do not help the image of Civil-3D.
Sinc
Rail Community
