Here is an idea -
Create your surface in Civil 3d, display the TIN lines, and use the
Surface - Extract from Objects from Surface to extract the 3d lines and
then submit those to the GIS system.
Matthew Anderson, PE CFM
alberto_go wrote:
> Thank you for your response Matt and John... it's for surface creation... I know I can use the supplementing factor when adding it as a Breakline or as a Contour onto my surface; however, I need the vertices in my 3dpoly so that my GIS people can actually use it and get a representative TIN in GIS....
> Honestly, we're going in some circles over here, and I'm sure there's got to be a better way of doing this... Scenario: we have a channel that we will be improving, and I need to provide a FG surface to my Water Department people so they can run their HEC-RAS analysis. The problem is that I can not provide them directly with the TIN so they can use it; we have to have the GIS guys make it a TIN first so they can use it... We've tried *.xml, *.tin (via LDD), etc, but their software won't read my TIN's, only the ones that GIS produces... I know we're doing something wrong...
> I am excited that Autodesk (Lucy) will be having a Webcast this coming wednesday (9/09/09) on this issue ("From GIS to design and back to GIS")... I already set up a meeting here at my company between us (Transportation), the Water and GIS people to attend this class... I'm sure they will point out some stuff that can help us improve our process...
> Alberto Gonzalez, PE
> Civil 3D 2009
> Phoenix, AZ
