Click Add Attachment and use the Browse button to find it. Once the path is in Attacvhments box it should be set to go. Unless it's too big or the wrong type of file. What type of file are you trying to attach?
Allen
Allen Jessup
CAD Manager - Designer
Another possibility is that you can embed images directly in to the post using this button:
Allen
Allen Jessup
What browser and version are you using? Also what OS is your computer running?
Allen
Allen Jessup
Ok a few things to try if using IE please make sure you are not in "compatibility" mode as it is not supported.
Also make sure you are not blocking scripts from Autodesk or Addthis.com they are need for all features to work.
also please make sure you are using the latest releases of the supported browsers below (with JavaScript enabled):
Chrome
Firefox
Internet Explorer 8+
Safari
For mobile device browsing the latest popular mobile operating systems and devices with their default browsers (with JavaScript enabled):
iOS with Safari
Android with Android browser
Opera Mini
Blackberry Browser
Discussion_Admin
OK. Back to your original question. If I had to do this. I'd start out by setting cogo points on the surface with the points having a point style that referenced the block. However I haven't any idea of how to handle the orientation automatically.
Allen
Allen Jessup
My main concern is if the PGA's or soil nails will hit any buried utilities. I create a pipe network for the PGA's. Once the first one is created I can copy it based on the spacing in the wall schedule. This procedure is used to see if we are hitting anything.
To show the PGA's in the profile view, we usually place a block (a box) at the station and elevation of each PGA. This is faster than the pipe network method and produces better visual results.
For your application I would show the soil nails as a pipe network pipe. Once you create the first pipe in a row, copy it based on the spacing in the schedule.
Hope this helps!
i would suggest using sub-assembly composer to draw the bolts (with the appropriate targeting parameters) and add the bolts to the surface by creating a corridor from the designed sub-assembly.
