AutoCAD Civil 3D General Discussion
*Expert Elite*
485 Kudos
Post 11 of 21
Re: Adding Retaining walls to a surface
03-13-2013 06:43 AM in reply to: jmayo
johnm wrote:
the designer should make sure that the embedded portion wall is not going to be on the neighbors lot.
That's hanging over my head right now. I'm supposed to be completing acquisition maps. But the retaining walls haven't been designed yet. So what we'll need to include the footings is just a guess at this point.
It's good you brought these issues up. I was just addressing the use of Featurelines in wall design and surface creation. There's always much more to the story!
Allen Jessup
*Expert Elite*
245 Kudos
Post 12 of 21
03-13-2013 07:19 AM in reply to: AllenJessup
HTH. This of course will not matter if the wall is not constrained by surrounding stuctures or parcel boundaries.
Here's a nice example of feature line retaining walls built into the surface for the OP. There are 4 or 5 here. It shows the top inside walll face as CColes discussed.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
*Expert Elite*
327 Kudos
Post 13 of 21
03-13-2013 05:12 PM in reply to: jmayo
Wow! They're re-grading the Partenon :smileywink:
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
*Expert Elite*
245 Kudos
Post 14 of 21
03-13-2013 06:13 PM in reply to: Joe-Bouza
Well now we all now know your not Greek... or an architect :smileyhappy:
That was for a lake front log cabin addition. :smileysurprised:
John Mayo, PE
IDSP 2014
Active Member
0 Kudos
Post 15 of 21
05-09-2013 08:32 AM in reply to: AllenJessup
Hi
Plaese if it is possible,could you please share the DWG file of this example?
I appreciate you in advance,because it is very useful for me
Sincerely
*Expert Elite*
245 Kudos
Post 16 of 21
05-10-2013 08:46 AM in reply to: AllenJessup
Sorry I took so long to respond. I was away for a few days.
I had to remove data from this file and place the basics for these walls into the NCS template.
There are two methods to building walls here.
Wall 1 - Feature lines extracted from a corridor. I like the profile control and profile superimposition to to display the wall with this method. I use this most when the contractor bids by wall face area and when a profile is needed to spec anchoring and/or grid systems.
Wall 2. Drafted Feature Lines - Draw them as you need in plan. Assign elevations and add the feature lines to a surface. I use this most often for smaller (<6') boulder walls and landscape walls.
These same methods can be used to construct many other things like curbs, buildings, ponds, swales, etc.
The 2.6 MB file is too large to post here. :smileysad:
Send me an email and I will deliver. Sorry I don't do dropbox or stuff like that.
johnm       at     conklinassociiates        dot          com
John Mayo, PE
IDSP 2014
Active Member
0 Kudos
Post 17 of 21
05-10-2013 10:06 AM in reply to: jmayo
Dear Johnm
Plaese if it is possible for you send me the dwg file that is so useful for
me.
I appreciate you in advance.
Sincerely
Hamid
Active Member
0 Kudos
Post 18 of 21
05-10-2013 02:05 PM in reply to: AllenJessup
Hi Allen
My email address is Hra1981@gmail.com.
Sincerely
Hamid
*Expert Elite*
245 Kudos
Post 19 of 21
05-13-2013 07:21 AM in reply to: hra1981
I sent the file. Did you receive it?
John Mayo, PE
IDSP 2014
Active Member
0 Kudos
Post 20 of 21
05-13-2013 07:43 AM in reply to: jmayo
Hi
I didn't recieve that.
Sincerely
Hamid
Post to the Community
New Post
