Can someone give me detailed instruction on how to add the quick elevation edit for feature lines to the double-click actions? I have tried everything under the sun (except for the right thing) to get it to work. Many thanks in advance.
Solved by BrianHailey. Go to Solution.
Create a double click action in your CUI and then drag the command to the action. Just make sure you use the exact name of the object in the double click action.
Here's a video showing how it's done:
Thanks Brian. The main ingredient that I was missing was the Object Name. I was putting the Quick Edit Name in there. Thanks again!!
