Active Contributor
Redli1
Message 1 of 16 (368 Views)
Adding Profile Elevation
368 Views, 15 Replies
01-21-2013 12:28 PM
I have a surface profile 1 and a corresponding water level profile 1 of a flood plain. Now I get an updated surface profile 2 and the engineer ask me to ajust the water level according to the difference of surface level 1 and 2.
How can I add a irregular distance (water depth)  to surface profile 1?
troma
Message 2 of 16 (367 Views)
Re: Adding Profile Elevation
01-21-2013 12:30 PM in reply to: Redli1
Not sure exactly what you're trying to do.  Does copying the surface help?  Then you can raise or lower the copy by the necessary amount and add that surface profile to the profile view.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
Redli1
Message 3 of 16 (363 Views)
01-21-2013 12:42 PM in reply to: troma
At each station the delta (suface profile 1 - surface profile 2) is different. I have to adjust the water level profile according to this delta
Valued Mentor
fcernst
Message 4 of 16 (331 Views)
01-21-2013 02:16 PM in reply to: Redli1
Do you know SAC?
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Active Contributor
Redli1
Message 5 of 16 (325 Views)
01-21-2013 02:38 PM in reply to: fcernst
so far I don not have a corridor. why should a make one?
Valued Mentor
fcernst
Message 6 of 16 (323 Views)
01-21-2013 02:45 PM in reply to: Redli1
I can quickly kick out your required adjusted profie and floodplain delineation all in one shot.
Fred Ernst, PE
C3D 2015
Ernst Engineering
Active Contributor
Redli1
Message 7 of 16 (314 Views)
01-21-2013 02:58 PM in reply to: fcernst
I hope somebody else can help me?
Valued Mentor
fcernst
Message 8 of 16 (310 Views)
01-21-2013 03:08 PM in reply to: Redli1
Oh ok if you don't have time to explore that,  you can just post the drawing with the profiles and I can do that for you real quick, no charge.
Fred Ernst, PE
C3D 2015
Ernst Engineering
troma
Message 9 of 16 (290 Views)
01-22-2013 05:18 AM in reply to: Redli1
Is your water level profile from a surface too?
If you do a volume surface between Surface1 & Surface2, this will give you the difference between them at every station.  You could then paste that volume surface into a regular surface, and do another volume surface between that and the water surface.  This will add the difference between the first two onto the water surface.  But you will have to figure out which one is Base and which one is Comparison in each case.
Valued Mentor
fcernst
Message 10 of 16 (283 Views)
01-22-2013 06:34 AM in reply to: Redli1
So many good options out there...
Here's another one:
You can always output the profiles to XML and quickly get the data to crank on in Excel. Then bring it back with XML:
<Profile name="Main RD">
<ProfAlign name="Main-FGCL">
<PVI>0.507625059359 2506.</PVI>
<PVI>582.340948472239 2523.219164741822</PVI>
<PVI>1511.652753557886 2507.38066067943</PVI>
</ProfAlign>
</Profile>
Fred Ernst, PE
C3D 2015
Ernst Engineering
