Hello...
I'm trying to figure out how to add referenced elevation information to the horizontal alignment geometry points. I've edited the style and added a 'Reference Text' value and then added 'Profile Elevation' to the contents. My problem is I can't for the life of me figure out how to actually tell it which profile I want to reference so all I get are "???" in the note.
When dealing with a single label, it will prompt me for the elevation I want to reference when I place the label, or I can select to the label and edit it's properties to add/change the referenced profile. With the standard geometry points labels, when I try to select one of them, it selects all of them (which is fine since I want all of them to reference the same profile), but I can't find any way to actually edit/add the profile that I want referenced.
Anyone know how to do this?
I can always create another label style and add them to each geometry point one at a time, but it just seems like there should be a way to do this with the normal geometry point label style.
Thanks in advance for any help/info.
Kurt
Solved by Jeff_M. Go to Solution.
