I have successfully added ductile iron pipes using the content catalog editor. I did this via "Import Part", "Without .CONTENT file"...
I did this because I needed to add 42"-64" sizes. It appears to have worked fine... but more testing is underway.
My concern is that for the new pipes I have no preview for the new pipes in the editor. To illustrate:
Here is what one of the existing pipe records shows:
Here is what one of the new pipe records shows:
I noticed that the DWG and IMG directories that correspond to me SQLLite database name contain drawings and images named the same as the PID for existing pipes/records but the new ones do not have corresponding dwg's or png's. Does this matter? If so how can I create and get them linked?
Thanks for any help.
Chris
Solved by saifumk8. Go to Solution.
I found solution myself, steps are below.
1. Show Part Family ID column
2. Copy Part Family ID
3. Create a .png file with name as the copied ‘part family ID’ and close and reopen Content catalog editor.
¿Cómo creaste las tuberías? , realicé los pasos que muestran en los foros, y cuando dibujo en el civil 3d no aparece la línea,de tubería, por favor puede indicarme los pasos que siguió para adicionar las tuberías.
