I hope I am using all the correct terminology and the explanation is some what clear...I have created an easement after I selected the line callouts and created my parcel table I realized I missed selecting one of my line labels and it is missing from my table. I know I can just erase the table and then reselect all line callouts to create a NEW table, but I was wondering if there was a way to just select the line callout I missed and have it added to the parcel table without recreating a new one.
Thanks in advance for any help...
Solved by quinndbq. Go to Solution.
If you already have the table placed in your drawing, just preselect the table and select Add Items from the contextual ribbon. You can also find an option on the right click menu if you preselect the table object and right click...selection.
Hope this helps.
Thank you !! Now, when I add the missing line callout it is placed at the bottom of the table. Is there a way to re-order?
