Hi.
I'm looking for a way to add a marker with location & elevation data to the profile (not the bands).
Only mention i found in this forum was for civil2011 (i have 2013) and it is no longer available.
Thanks.
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
Joe Bouza
Joe Bouza
I am playing around with this. What does the text height have to do with this expression? Is it needed?
Mark Green
Mark Green
All I want to do is label the grade breaks either with a HP Sta., or LP Sta.
Mark Green
The original expression is a neat little expression that will work nicely on many project between the begining and end of the profile line. Yes, the begining and end labels are given HP/LP text because the expression looks only for a simple True/False statement for the grades in & out. You could edit the expression:
IF({Grade In}>{Grade Out}, {Text.Height},0)
to something like:
IF(OR({Grade In},{Grade Out})=0,0,{Grade In}>{Grade Out}, {Text.Height},0))
Which first check for null/NA/zero T/F and then proceed; however, you could also just edit your label station range to exclude your begining and end station for the HP/LP label style and then add the begining & end stations seperately.
