I have using Geopak and Civil 3D equally. The thing i love about Geopak is the way it spits out the cuve data directly usable in plan-profile sheets, unlike Civil 3D where you first generate a Table and then manually add it in the sheets.
Is there a way to customize it to do it the way Geopak does?
Solved by Jay_B. Go to Solution.
@L3GO-Ed wrote:
Looks good. So can such labels be generated for all the curves on the Alignment in a single process. How?
The label shown is an Alignment "Curve Label", so it's not a completely automated solution but only involves 2 steps to place the labels.
Specifying the "Curve Group Index" within the Geometry Editor and then picking each curve to place the label.
Considerably less work than what the OP had been doing IMO.
There may be other ways of doing this within a Label Set but I wasn't able to find all of the necessary components within the various Alignment Label Styles which can be included in a Alignement Label Set.
Looks great Jay. That is exactly what i am looking for. But can you elaborate on the steps to do it?
I went to the Geometry Editor, but couldnt find where to specify the "Curve Group Index"
Thx.
Attached is a 2012 dwg with the Alignment Curve Label created.
Feel free to use label as is but first verify all curve parameters within the label are reporting the proper information.
