Civil 3D Forum
Adding FG labels to section - band style
1 REPLY 1
739 Views, 1 Reply
1.    I am trying to label the FG centerline of my sections in section view and are given three options under the setion view properties -> section tab (Existing ground, Proposed cross section and proposed surface.) I am not drawing the FG surface in my section but am including the corridor section with the existing ground.  When i move to the "Bands" tab to label my "Section2" I am not given the option of the Proposed cross section but only the Existing ground and proposed surface.  How do i get the corridor section that i am drawing in section view to be the one that the band labels when it isn't an option.
2.    I have data referenced in the Exisitng and Finished Surfaces but when i go into Section View Group Properties -> Section Views -> change band set-> the only option i have for my band set to label is the Existing ground surface.  The Finished ground surface doesn't show up.
Jeff
1 REPLY 1
Jay_B
In order for the Finished Ground Surface to show up so it can be specified as "Surface "2 (or proposed surface elevation) is by first sampling the surface here:
Sample Line Group Properties>Sections Tab>Sample More Sources...>and Sample the FG surface.
Now it should be available to select in the Data Band for labeling.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Rail Community
