Civil 3D Forum
Adding data to points
11 REPLIES 11
Message 1 of 12
712 Views, 11 Replies
Is there a way to have multiple elvations on a single point?
Such as with a top & bottom of curb.
I have tried to add a component to the style, assign the name as the control, and put in the elevation
I want, but you can't have multiple points with the same name.
anyone.................
11 REPLIES 11
Message 2 of 12
Lisa_Pohlmeyer
If the elevation is a consistant difference, as your example of top & bottom of curb, you could write an expression then add that to the label style for the elevation.  In this case I've created the expression of Point Elevation - 0.5 and shown that below my TC: elevation as FL: (gutter).
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Message 3 of 12
Not got civil3d in front of me but throwing ideas about. You could do this using referance text, perhaps a dummy point or a dynamic Feature line. You'd need to set each one manually so time consuming. A simpler way would be to perform a cross section set out report and edit so that you use point codes in a csv file. Then with description keys you could set up for each desired value and display on the channel using the full description. Won't be dynamic but will work.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 4 of 12
stacy.dunn
You can add the additional elevation as a UDP and then it can use it in a label style component.
Stacy Dunn
Message 5 of 12
ericcollins6932
To answer the original question, you cannot have a vertical wall in C3D (otherwise known as a point with equal xy and different z.
You will have to offset your top of curb horizontally a hair. (Scientifically speaking, a hair being a very small amount)
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 6 of 12
MikeEvansUK
Untrue. You can have a vertical wall in civil 3d which i often do but you can't have two points co-existing in the same xy plane in a surface model and generate a vertical surface.
Mike Evans
Message 7 of 12
IanMcClain
in reply to: stacy.dunn
As Stacy suggests, User Defined Properties are a good way to do this.
see here for some info:
http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-31D42176-1ED4-4074-99D3-A348CB832F1-585.htm
I also have used expressions for things like curb and gutter, where all you want is a label that takes the point elevation and adds or subtracts a curb height to it.
Ian McClain
Message 8 of 12
MikeEvansUK
in reply to: IanMcClain
Thank god for English was afraid the op would get lost with the term udp. I was for a bit. If the kerbface is constant use that method otherwise you may need to manually edit the point label. Different styles for kerbface but you can override the text on each point. (And other labels) . Few methods for this, none dynamic yet so take ur pick.
Mike Evans
Message 9 of 12
in reply to: MikeEvansUK
For situations where I need a top & bottom of curb I created an expression with a consistant elevation difference.  I also have times when I have a wall top and then changing ex ground elevations. For these I used the UDP
and both are working great. Thank you for your help
Message 10 of 12
onsionsi1
can you explain the stepses to do that. I don't know what do you mean of UDP.
For your advice
Thank you.
Please do not forget approve as solutions and Points
to Remember Please Accept as Solution and Kudos Please
Message 11 of 12
troma
in reply to: onsionsi1
UDP = User Defined Property.
Read all the comments here carefully and read the links, look at the pictures posted.  There is probably enough information to get you going.
Mark Green
Working on Civil 3D in Canada
Message 12 of 12
stacy.dunn
in reply to: troma
Custom properties from online help menu.  It should give you enough info to get them built.  You should also try searching this group for UDPs.  There have been several explanations.
http://docs.autodesk.com/CIV3D/2013/ENU/index.html?url=filesCUG/GUID-05D9F8B4-010B-4242-B96A-0961BE2...
Stacy Dunn
Rail Community
