Civil 3D Forum
Adding CGList to the CUI
3 REPLIES 3
Chasethewind
465 Views, 3 Replies
I am trying to add CGList to the shortcut menu through CUI, however I cannot preselect an object.  It wants me to select an object after I right click and pick the command.  Pickfirst is already set to 1.  Any ideas?
Cory
3 REPLIES 3
jrauch
in reply to: Chasethewind
Your command macro starts with ^C^C.  That cancels out your selection set, so you can't take advantage of PICKFIRST. I'd try removing "^C^C" and see if that works for you.
-John J. Rauch, P.E.
Chasethewind
in reply to: jrauch
That doesn't seem to work.  It resets the command and wants me to still pick an object.  Then it gives me sub commands (pick object or points).  Just as if I typed it in the command window.
Cory
jrauch
Sorry, I didn't test it out before I replied- just saw the ^C^C and figured that was the issue.
It looks like this particular command does not support PICKFIRST. It doesn't even seem to support "previous selection".
It looks like you'd have to design a custom tool to do accomplish what you're looking for.
Rail Community
