AutoCAD Civil 3D General Discussion
Member
JAY25
Message 1 of 3 (256 Views)
Adding Building levels to existing ground
256 Views, 2 Replies
10-12-2012 01:31 AM
I have an existing ground surface with all different z co-ords and im trying to add three proposed buildings to my exisiting ground with all the builidngs having a level of 32.5 as a minimum, however at some points the ground is higher than 32.5 and I only want to raise my existing ground to 32.5 within the proposed buidling layout if it is below 32.5 as im doing a flood calculation. What do i need to for this? Thanks.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 3 (253 Views)
Re: Adding Building levels to existing ground
10-12-2012 01:44 AM in reply to: JAY25
I would do the following steps:
  • create a user-spezified contour at 32.5
  • extract that contours to get polylines (command _AeccSurfaceExtractObjects)
  • copy your EG-surface
  • use the extracted contours to make islands in the copied surface
  • now you can raise up the copied surface
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
Joe-Bouza
Message 3 of 3 (221 Views)
10-12-2012 03:24 PM in reply to: JAY25
Changing existing ground is a sure way to make any grading problem go away :smileywink:
Surley I jest, but typicaly we don'r change existing ground we build on it and cut into it - two different models. Then they can be combined.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Need installation help?
