Civil 3D Forum
Adding an Image from a WMS error: "Failed to open FDO connection"
9 REPLIES 9
Message 1 of 10
Jay_B
1131 Views, 9 Replies
When attempting to attach WMS data, Map Task Pane>Display Manager Tab>Data>Data Connect dialog>Data Connections by provider.
After entering the server name or URL and choosing "connect" I get the following errors:
"The HTTP request URI was not found by the server"
It seems to work just fine for other users using the same steps.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
9 REPLIES 9
Message 2 of 10
antoniovinci
in reply to: Jay_B
Please paste here the exact WMS address you are using to connect.
Message 3 of 10
Jay_B
in reply to: antoniovinci
Thanks for the reply, the address is
http://geoint.lmic.state.mn.us/cgi-bin/wms?
C3D 2018.1
C3D 2016 SP4
Message 4 of 10
ericcollins6932
in reply to: Jay_B
That URL seems a little short - maybe double-check the origin?
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 5 of 10
Jay_B
in reply to: ericcollins6932
The URL is correct and can be found at This site.
C3D 2018.1
C3D 2016 SP4
Message 6 of 10
antoniovinci
in reply to: Jay_B
Just verified in Gaia3, that WMS address is alive and kicking:
if it works for you too, I fear your Autocad lacks something...
Message 7 of 10
Jay_B
I was able to bring it into Microstation V8i (which leads me to believe it's on the AutoCad C3d side of things too).
Have any ideas where to start looking for the culprit?
(I can easily find the usual one from across the keyboard) Smiley Happy
C3D 2018.1
C3D 2016 SP4
Message 8 of 10
antoniovinci
in reply to: Jay_B
Nope, I'm sorry, J: I use opensource Gis to grab WMS tiles in Geotiff format.
Message 9 of 10
Jay_B
Thank you for verifying the url works!
C3D 2018.1
C3D 2016 SP4
Message 10 of 10
Jay_B
Finally success! As it turns out the location I was copying url from (an in house pdf for) has something it doesn't like because when I copy url posted here and paste into server name or URL box it's working as expected.
Thanks again.
C3D 2018.1
C3D 2016 SP4
Rail Community
