Member
colbyhartman
Message 1 of 5 (233 Views)
adding a prefix to the end of cogo points
233 Views, 4 Replies
06-28-2012 06:18 AM
anyone, looking for help in adding a prefix to the end of a cogo point ie.(when we bring in info we have a top of curb and a face of curb shot and we add TC and FC to the text componite editor.) is there a process where i can add this at one time or set civli up to where when it processes the file to recognize them and add this automatically for minimize drafting time?
any help would be apprecative.
Distinguished Mentor
andrewpuller3811
Message 2 of 5 (211 Views)
Re: adding a prefix to the end of cogo points
06-29-2012 06:02 AM in reply to: colbyhartman
You do what you want with the description key sets using the Description Key Format to create a full description that you can use in labels etc.
If you have a raw code and want to add something to the end of it, use something like this in the Description Key Format - "$* TC" without the quotes. The $* tell civil 3d to include the entire raw code and then add a space and then TC.
As an example, we have one Description Key with the raw code of "GR*" and the Description Key Format as "Grate $*" which takes something like "GR01" will show in the full description as "Grate GR01"
If you want to look into it further, check out the Description Key Format Section of the help.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
Member
colbyhartman
Message 3 of 5 (205 Views)
06-29-2012 06:30 AM in reply to: andrewpuller3811
i guess i should have elaborated a little more, we show the additional info with the elevation on our spot shots. so you would have the point number elevation and description. but we only show the elevation and marker on our plats. i need the "TC" added to the end of the elevation when the raw description is imported.
Jeff_M
Message 4 of 5 (200 Views)
06-29-2012 06:44 AM in reply to: colbyhartman
Same as what Andrew described, then just be sure your PointLabel style includes the Full Description after the elevation.
Member
colbyhartman
Message 5 of 5 (196 Views)
06-29-2012 07:22 AM in reply to: Jeff_M
thanks to both of you guys, it helped out this will save hours on drafting time.
