Civil 3D Forum
Adding a corridor surface to a the eg surface?
3 REPLIES 3
fuglsang1000
1514 Views, 3 Replies
I am trying to visualize a road project. The problems is, whenever the corridor surface goes below the EG surface (when the road is in cut) the EG surface is the only visible surface.
I sort of need to subtract the corridor surface from the EG surface, or merge the both surfaces into one.
Anyone knows how to do this?
Iam using civil3D 2012 and 3d MaxDesign 2012
-thanks
3 REPLIES 3
Create a new surface.  Expand Definition, right-click on edits and choose Paste Surface.  Paste the existing first, then paste the corridor surface.
Todd Rogers
neilyj666
in reply to: ToddRogers-WPM
I'd also extract the corridor surface boundary and add to the existing as a non destructive breankline - this will give the surface better definition
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
rafa8790
in reply to: fuglsang1000
I think I had the same problem, I exported the corridor surface to a XML and then it became a Thin surface.
Then I could paste it to the EG.
Rafa8790
Rail Community
