Civil 3D Forum
Add subassembly to corridor
11 REPLIES 11
Message 1 of 12
sboon
12083 Views, 11 Replies
We are trying to edit a small portion of an existing corridor by adding a generic daylighting subassembly.  The add subassembly tool in the Corridor Section editor works, but we get an error because the new sub doesn't have a target surface specified.  Does anyone know how to add a target for a sub that is added after the corridor was created?
Steve
Civil 3D 2012 & 2013 & 2014
Toshiba Qosmio X505-Q890
2 x i7 - Q740 quad core CPU's
8GB of RAM
60GB SSD + 500GB HDD
NVidia GeForce GTS 360M - driver 8.17.13.0697
Win 7 Home Premium
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
11 REPLIES 11
Message 2 of 12
doni49
in reply to: sboon
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 3 of 12
sboon
in reply to: doni49
I've attached a drawing to help clarify the problem.  The assembly used here has no daylight on the right side, but there is a detatched subassembly in the drawing.  At station 0+25 I have already used the Add Subassembly tool in the Corridor Section editor to add the daylight.  I cannot see any way to edit the target parameter however.
Steve
8GB of RAM
Win 7 Home Premium
Steve
Message 4 of 12
doni49
in reply to: sboon
Steve,
It worked for me.  I attached your SA to the assembly and when I went to the corridor properties, chose Target.  The right daylight needed to have the target set.  Once I did, I rebuilt the corridor and it worked without errors.  I saved the dwg file and it's attached.
Don Ireland
Message 5 of 12
sboon
in reply to: doni49
That's not what I'm trying to do here Don.  I want to attach a single instance of a daylight sub to one corridor section only.  The software will allow me to attach other subs to a corridor but there is a problem with daylights because there doesn't seem to be any way to specify the target.
Steve
Steve
Message 6 of 12
doni49
in reply to: sboon
 I must admit that I was surprised to think that I was going to be able to help you with something as simple as this (or at least as simple as I thought it was).  The things you've assisted with in the past have been much more complex than the task as I understood it.
 I'm sorry I guess I'm not understanding that request.  What exactly is the end goal (maybe with a sketch)?
Don Ireland
Message 7 of 12
doni49
in reply to: sboon
Steve
Steve,
I've read and re-read this post a bunch of times.  When you say "attach a single instance of a daylight sub to one corridor section only", it sounds like you want to attach the right daylight over a specified station range (region).  Won't that require a second assembly along with additional regions?
Don Ireland
Message 8 of 12
sboon
in reply to: doni49
If you open the corridor section editor, and expand the corridor edit tools panel on the Ribbon then you'll see the Add subassembly tool I was trying to use.
The original problem was in a much larger corridor, where we needed to replace the normal daylight subassembly with a copy of DaylightMultiIntercept for a couple of stations.  Deleting the existing daylight sub was easy enough, but we were trying to figure out how to replace it.  I think the person who was working on it faked in some linework to get the corridor surface looking right, so we are OK for now.
Steve
Steve
Message 9 of 12
fcernst
in reply to: sboon
...but we were trying to figure out how to replace it...
Implement a Conditional subassembly
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 10 of 12
doni49
in reply to: sboon
AHHHHH.  That explains my confusion.  When you said "a section of corridor", I thought you meant section as in "part of" but you litterally meant cross-section.
Don Ireland
Message 11 of 12
sboon
in reply to: doni49
<chuckle>
Now you know what it's like to be an EE, trying to figure out the questions from other users. Smiley Happy
Steve
Message 12 of 12
in reply to: sboon
How about creating a new assembly with the subassembly and run in a region for 0.1 ft., 0.05 ft. each side of the cross section in question.
Rail Community
