I have my major & minor stations labeled on an alignment but I need to add a station label at 1+35. Just labelling station...not station/offset. I know I can add labels under Annotate...Add Labels...Alignment, but I don't see where I can add just one station label on the alignment. How can I add a label?
Solved by doni49. Go to Solution.
One way is to make a copy of an Alignment Station/Offset label and edit it.
Station/Offset Label Style name > Edit > Layout Tab > Text > Contents > eliminate all but station info.
Select Alignment > Add Labels on Ribbon > "Add Alignment Labels" > specify new sta/off label style created > Add.
Edit station label group. Then......
Don Ireland
Engineering Design Technician
