Is there a way to add an additional, individual contour line to a surface at a specific elevation? For example, if we are creating an as-built surface that includes a pond, we might want to have a contour at the top of the pond, or if we are creating a proposed surface, we might want to add a contour line at some proposed normal pool elevation, neither of which will probably fall at an even foot.
Thank you,
Solved by Jeff_M. Go to Solution.
User-defined contours.....make sure your Surface style is set to display them, then in the Surface properties, Analysis tab, select User defined Contours for the Type, enter 1 for the range, then change the elevation to the one you want in the Range Details panel.
Yes, that is a "user contour", define it in the surface properties analysis tab>> analysis type >>> user defined contours. You can make as many as you like. One caveat; your surface style needs to be set to display "user contours".
Joe Bouza
Now how do i extract these user defined lines and have them stay when i switch back to 1 foot contour surface? Extract button is deleting them when i change surface back to one foot contours.
neilyj (No connection with Autodesk other than using the products in the real world)
Yes and they become polylines (actually creates two polylines on each one), but when i switch surface style back there is a hole there where they were. It used to work. I am in ACAD 2014.
i was able to add the user contours for the contour elevation i wanted for my pond but whenever i try to edit surface after that (swap edge, add surface point) the user contours get deleted, any idea on what this may be?
