199 Kudos
Post 1 of 5
Add rebuild Surface to Ribbon and Mouse
336 Views, 4 Replies
12-19-2012 10:49 AM
I would like to add a Rebuild Surface command to my Ribbon Modify Panel. I would also like to have it included in my Right Click menu after a surface is selected. There doesn't appear to be any way to initiate a surface rebuild from the command line and I don't find a command for it in the CUI editor.
There does seem to be a rebuild command in the API but I am not a programmer. Is this possible without programming?
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
This is how I customized my CUI to get around the issue of not having that functionality built in. I added a button to the quick access toolbar.
Once in the CUI editor
1. Make a new command called "REBUILDSURFACE" by clicking the star/asterisk in the command list.
2. In the new command define the macro as:
^C^C_REBUILDSURFACE
3. Drag the new command to the Civil 3D Quick Access Toolbar
4. Close CUI and select your surface and then click the new rebuild surface button.
Hope that helps.
13 Kudos
Post 2 of 5
Re: Add rebuild Surface to Ribbon and Mouse
12-19-2012 11:10 AM in reply to: Neilw
^C^C_REBUILDSURFACE
Hope that helps.
-Dustin
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
199 Kudos
Post 3 of 5
12-19-2012 01:16 PM in reply to: dasindog
That worked nicely. How did you know about the REBUILDSURFACE command? It does not show up when I searched for it in the CUI editor.
Thanks Dustin
WIN 7 64 PRO
RADEON 6450, 1 GB
13 Kudos
Post 4 of 5
12-20-2012 05:17 AM in reply to: Neilw
Noticed it while flipping through the command autocomplete one day. Now you have me looking into modifying the ribbon. I'll update you if I figure out something worth sharing.
-Dustin
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
76 Kudos
Post 5 of 5
12-20-2012 05:44 AM in reply to: Neilw
Not to take away from the solution, but when I select a surface, the rebuild surface command is already on the rt-click menu.  I haven't modified my stock CUI at all.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
