I am trying to add parts to a profile the same way I have for years now in Civil 3d and getting the same message....not matter how I try to add them. I am not picking the profile first, nor do I think you even can. I am running the command, selecting the parts I want to add to the profile, hitting enter, and then selecting the profile view I want to add them to when prompted for it. Has anyone found a solution to this problem. I have just started having it. In another drawing I just erased the part and added a new one and that fixed it but in my current drawing nothing I seem to do allows me to draw the parts in the profile view.
Any help would be very much appreciated.
Thanks!
I'm having the same issue. I've had no problems up till recently and I'm wondering if my drawing is now corrupted. I can select add parts, select the profile view and then nothing appears.
Frustrating!
Did you ever get this to work again? I was cruising along with everything working fine, then all of a sudden I'm
getting the same error you're getting.
@jak79 wrote:
I am using Civil 3D 2010 & getting an error message when I run the command (AddNetworkPartsToProf) to add network parts to the profile.
Here is the message I get when I select a part of the pipe network to draw into the profile. "1 object was of the wrong type. All objects in the pickfirst set were filtered out, please select again".
Any help is appreciated.
I do not know if you still have the same issue, I was not able to draw a fixed tangent line to my profile because it was telling me this note: "1 object was of the wrong type. All objects in the pickfirst set were filtered out, please select again.", I turned off the pickfirst option "Ctrl+Backspace" and then it let me select the profile and activate the draw fixed tangen line command.
